4 members (Maybellene, klhansen, 2 invisible),
87
Mod | | | Forums66 Topics128,211 Posts1,057,468 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | for those of you that have an engine hoist and welding skills and a need for a cab hoist. in the march issue of classic truck magazine there is an article and picture story on how to build a cab hoist using a engine hoist. very slick. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I just put a 2x4 or 4x4 between the hoist boom and inner roof. I have never had a dent yet.
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | My biggest mistake is to HAVE a hoist. Also a mistake to have bought an engine stand. Both could have been rented or borrowed and saved all that space they take up in my garage.
~Jim
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Ya must have just got it this afternoon Ron, I'm still on Februarys issue here. DG
Denny G Sandwich, IL
| | | | | Joined: Sep 2009 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 35 | If you have an engine hoist, all you need is a pair of straps to remove/replace a cab. http://img10.yfrog.com/i/project57007.jpg/ | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | all you need is a 2 x 6 or 4 x 4 and the engine hoist http://rides.webshots.com/photo/2404821430101989507AsJlJUalso works for lifting the bed and a bunch of other things.
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I bought an 1K lb capacity electric hoist from Harbor Freight. Slung it over garage rafters. Works like a champ.
Drew
| | | | | Joined: Sep 2002 Posts: 153 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 153 | I used the lumber though the cab method to remove the cab from the frame.
Since then I added a 2x2 steel tube and I can telescope my engine hoist. I built that to make the removal of the fiberglass Silverado bed cover a one man job with straps.
The extra length reaches lots more stuff but I need to be careful of weight limits. 1946 Chevy Half Ton ('56 235, '86 T5, '79 Camaro Z28 rear end, working on the '85 Jaguar XJ6 IFS) 1976 Margay Panther X, MC91B | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I've done the rafter trick also, but re-enforced the joists with another 2x4 and also cut a couple posts and wedged them between floor and joists for added strength. After chassis was rolled out, I set the body down on a roll around dolly made from scrap. Also try to have a helper aound during 'Lift Off'!
I read that article also in Classic trucks, hope the guy has good health insurance. Will be watching for him on Americas Funniest Home videos!
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I've done the rafter trick also, but re-enforced the joists with another 2x4 and also cut a couple posts and wedged them between floor and joists for added strength. That's a good point so I should have added to make sure your joists can carry the weight. I stick built my garage and code had me using 2 x 8's for joists and rafters. Factory made trusses are generally made of 2 x 4's so added support is definitely needed.
Drew
| | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | I took the cab off my 1954 Chevrolet pickup with my engine hoist, I didn't know you couldn't do it so I did it anyway. The result was I removed the 3 window cab and put on the 5 window cab with no problem at all. I am getting ready to take the cab off of my 1932 Chevrolet pickup to box the frame for a much stronger engine than it was made for, and I expect no problem with that either. Next project will be to remove the body from my 1932 Chevrolet 2 door sedan so I can box that frame also, I guess it will take some careful measuring to balance it but I am confident it will work O.K. | | | | | Joined: Mar 2009 Posts: 19 New Guy | | New Guy Joined: Mar 2009 Posts: 19 | I know this is an older thread but I used a 4x4 on top of my engine hoist, it took me a couple tries to make sure it was completely level once lifted but worked great. Here is a link to the classic truck build.. Classic Trucks
I never let the truth get in the way of a good yarn..
| | | | | Joined: Apr 2006 Posts: 273 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 273 | This guy gave me some pointers a few years ago. I feel kinda guilty for not keeping in touch with him.  | | |
