2 members (2-Ton, mick53),
75
Mod | | | Forums66 Topics128,030 Posts1,055,419 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 30 New Guy | | New Guy Joined: Nov 2009 Posts: 30 | I want to repair the cracks in my steering wheel (1954) but not sure how to remove horn button and wheel. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | The horn button press fits into the retainer and will pop with a screwdriver blade. Then you undo the bolt and remove the retainer. Once that is done there are 2-5/16" holes in the wheel itself that you thread into bolts that go through a wheel puller(I bought as whole kit at Harbor Freight you can spend a lot or a little). You can clear the threaded holes in the wheel by blowing them out with your air hose and a little oil in them doesen't hurt also since they are dry and can strip out or cross-thread. You place the extractor against the center and tighten, usually they pop pretty easy but don't get your face close where you can lose a tooth or bust your nose. Sometimes before I pull one that has never been off I soak the knurled area around the wheel with PB blaster to help loosen them up. | | | | | Joined: Nov 2009 Posts: 30 New Guy | | New Guy Joined: Nov 2009 Posts: 30 | Thanks for the info. Brad. I'll try it out this Saturday. | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Pappy, Just FYI I bought the Eastwood steering repair kit. Not worth it save your money. I have a 57 Chevy truck. I think after 50 years of being in the sun and heat it is too far gone. We repaired the wheel the best we could and I noticed last night the same cracks coming back. The wheel was rebuilt in October of 09. Not sure if after market wheels are any good. Maybe I will wait until I find an NOS one. Just a thought for you. Jon 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Feb 2008 Posts: 202 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 202 | Hi, Pappy, I would go for a reproduction wheel or a NOS wheel if you can find one. On my 49 1/2 ton there was a lot of cracks in the wheel and on the bigger ones you could see rust on the inner steel rim. From my marine work that rust WILL lift the repair off sooner or later.
Keep the 216's running. 1949 1/2 ton model #1314 (US 3104) Brian
