| | | Forums66 Topics128,180 Posts1,057,157 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#60990 05/28/2006 6:00 AM | Joined: Aug 2001 Posts: 79 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 79 | I am currently running 235-75R15 on my 72 Chevy Stepside.... They look dinky.. What was the original tire size on this truck and what radial size will best suit it. It doesn't have to be wide, but i'd like the tire to fit better in the wheel well. Thanks | | |
#60991 05/28/2006 6:26 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | original was 815x15 I believe, and the 15's do look undersized on that series truck - the 16's they put on the 3/4T looked a bit better suited - need to find a taller tire, but you won't fill those wheel wells!
Bill | | |
#60992 05/29/2006 2:49 AM | Joined: Aug 2001 Posts: 79 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 79 | Any suggestions on tire size? 255-75R15? | | |
#60993 05/29/2006 4:45 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I've put 31/10.50/15's on that body truck, they fill the wheel wells up nicely. You bhould get 15x8 wheels to use that size for the best perfomence. 32/11.50/15 will fit also, but they are a little tight. If you go to a 16" rim i'd suggest 245-75R16 or 255-70R16, they are the most common sizes in truck tires.
Bill Burmeister | | |
#60994 05/29/2006 7:13 PM | Joined: May 2006 Posts: 8 New Guy | | New Guy Joined: May 2006 Posts: 8 | I've got a '67 with 285/60/15 on 15x10 chrome mods. Looks pretty decent, but would look tougher with about a 2" drop.
1939 Chevy 1/2 ton AKA Light Delivery.
1967 GMC 1/2 ton short-step.
