8 members (Bisbee, 49Chief, DadsFirstPickup, D B Cooper, joe apple, Otto Skorzeny, cmayna, 1 invisible),
77
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,131 Posts1,056,723 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 40 Apprentice | | Apprentice Joined: Mar 2009 Posts: 40 | I finally found a T -5 to put behind my 235 , thanks for all the help. I couldn't do it without all of the input from you guys. I have read a lot on the web about people using auto trans fluid ? I put 80-90 oil ( not synthetic ) what is the best choice ? | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Run the numbers on your T5 to see if it is a world class. It may have a sticker on it with recommendations for the type of fluid, you should follow them. Check out this site. http://www.britishv8.org/Articles/Borg-Warner-T5-ID-Tags.htm | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | I have a non-world class T-5 from an '89 S-10 and also run Dexron II as per the '89 Chev shop manual. As was stated above, run the numbers to identify the vehicle it came from, then get a manual for it and read what it says about the tranny lube. I found the '89 Chev manual at the public library. | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | There has been some questions raised about the T5 lubricant so being who I am.......I've run the 80-90 weight in my used NWC (brass synchro rings) T-5 for the past 10,000 miles. It had gear lube in it initially and when I first drained and checked it for metallic particles both ferrous and non-ferrous, I found none. The transmission shifts smoothly, is quiet and the only difference I've noticed is that when the temperature gets down into the 40-50's before the engine warms up, the cold transmission shifts are initially a little stiffer. Having checked for metals at 5000 miles I found none.
On a used NWC (brass syncro rings)Hybrid Camaro T5 for my next project, the transmission came with Dextron ATF. Ditto on the negative check for metals in the fluid. I refilled that with Royal Purple SyncroMax which is a fluid recommended for the WC boxes.
Not wanting to open a can of worms on the forum......I will continue to use the gear lube in my truck box because of the normal operating temperatures here in sunny Florida and will run the RP SyncroMax (ATF)in my NWC Hybrid box. IMO.....the WC T5 with needle bearings and synthetic synchronizers requires ATF, while in temperate climates the gear lube OR ATF would keep your T5 happy. That's my story and I'm sticking to it!
Dave
| | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I've got an 85-86 T-5 in my 37 Chevrolet 1/2 ton pickup truck. I also have a 1985 S-10 Chevrolet Blazer Owner's Manual that specifically indicates that Dexron II, which has now morphed into Dexron III, is to be used in that particular T-5 NWC transmission.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I've tried them both & have settled on the ATF. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Amsoil Synthetic SAE 50 in mine in a variety of well beaten and abused vehicles.
