| | | Forums66 Topics128,078 Posts1,056,029 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2001 Posts: 34 | Looking for new wiper blades for my 66 C10 and the new blads don't work with my wiper arm style which is straight and doesn't have the curve on the end... how can a get an arm that will fit new style blade applications with the curve at the end... does a later year arm fit a 66, can I put an 1980s arm on a 66 wiper assembly? any help on this would be appreciated! | | | | | Joined: Dec 2008 Posts: 337 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 337 | | | | | | Joined: Jan 2007 Posts: 220 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 220 | I never liked the tension (or lack of tension) that the originals have. I found a wiper arm in autozone that fit the drivers side. They are called "Mighty Clear" and have part number 42873 (I have my originals in the package they came in). If I recall correctly they are for the rear window on a Jeep Cherokee. I removed the rivet and slightly spread the squeezed part to reverse one for use on the passenger side. I used a screw and nut to replace the rivet. | | | | | Joined: Dec 2001 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2001 Posts: 34 | | | | | | Joined: Jan 2010 Posts: 7 New Guy | | New Guy Joined: Jan 2010 Posts: 7 | Hi guys, new too the site but have been checking it out for awhile now... too Rusty 64 RIGHT ON FELLA the tip on the wiper arms finally gave my 65 wipers after a year without them... now just have too stop turning them on when passing the police. laffin | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | They are called "Mighty Clear" and have part number 42873 Are these chrome wiper arms or ar they black? Thanks, | | | | | Joined: Jan 2010 Posts: 7 New Guy | | New Guy Joined: Jan 2010 Posts: 7 | The wiper arms i got were black not sure if chrome was available | | | | | Joined: Jan 2007 Posts: 220 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 220 | Mine were black. Then again that is what I wanted. | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | I just replaced the wipers on my 64 just went to Shucks and got replacement arms they fit perfectly they are of much better quality than the factory arms and they except the common late model style blades not sure what the part numbers are but I will find out and post them soon. | | |
