1 members (Truckrolet), 156 guests, and 1 robot.
Topics128,115
Posts1,056,291
Members48,439
#60979 05/27/2006 5:09 PM
I need to replace the rear axle control arms (track arms?) that attach from the frame under the cab to the rear axle.. I was told that they are the same length regardless if you have a long bed or short. It just doesn't sound right to me... I have a short bed and the control arms are 58 inches long... Can anyone verify that the long bed control arms are the same length. Also, If anyone has a good pair of them that they would like to part with... I'd be highly interested.
Thank you much
Joe
'57 Chevy 210 (235)
'54 Chevy 3800
'49 Pontiac Streamliner (239)
'46 Chevy 3/4-Ton (216) (Sold)
'46 Chevy 1 1/2-Ton (Sold)
'50 Chevy Loadmaster Semi (Sold)
'68 Chevy Stepside (Sold)
#60980 05/27/2006 7:25 PM
they are the same, 63-72 long or short,, I just got rid of a set about a month ago,,sorry, brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#60981 05/27/2006 9:04 PM
I knew that 64-72 are the same,did'nt know that 1963 were the same.You can get them new for $450.00 a pair.Be sure to inspect a used set or you will be back to square one.It would be nice if you could locate a pair that have been sand or bead blasted.
1951 3100 Chevrolet
#60982 05/27/2006 10:37 PM
63 was the year they changed frames, but kept the old knee knocker cab til 64,,63 is an odd year due to that..brian
#60983 05/28/2006 5:29 AM
I appreciate the help... Just wish I could find a used pair in good shape.. I can throw $450 at it right now if you know what I mean. Thanks!
If anyone has a pair sitting around, please let me know!
'57 Chevy 210 (235)
'54 Chevy 3800
#60984 05/29/2006 9:24 PM
smokinjoe3,post what you need in the swap meet section"truck parts wanted".You will probably find them.
1951 3100 Chevrolet
#60985 06/05/2006 6:51 AM
smokinjoe, Do you really need to replace your control arms, I mean are they really trashed, bent, broken rivets etc. Mine were pretty rusty so I cleaned em up and replaced the bushings with OEM rubber ones. I tried the polygraphite bushings that are not supposed to squeek. Guess what a week later my neighbors were saying, "here comes ole Squeeky down the street.
#60986 06/05/2006 6:52 AM
