| | | Forums66 Topics128,057 Posts1,055,810 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 7 New Guy | | New Guy Joined: Jul 2009 Posts: 7 | I have a 40 chevy 1/2 ton. The previous owner only bolted the front of the cab. The blocks and bolts are set in the rear of the cab, but there is something missing between the frame and the long bolts. Can anybody tell me what goes there. Picture if possible. Thanks..gp
Still crazy after all these years 1939 half ton chevy truck gp
| | | | | Joined: Jul 2006 Posts: 232 New Guy | | New Guy Joined: Jul 2006 Posts: 232 | Its been so long since I did my 39 it hard to remember. I think after your place the bolt thru the cab/block/frame there is supposed to be a spring before you put on the washer and nut. I boxed my frame so i didnt use the spring. I may be wrong but I think it was to allow a little cab movement. Hopefully somebody that has done a restoration will pipe up. I went the hotrod route.
| | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | I'm going from memory here so bare with me. I think your 40 is just like my 46. There are 3 bolts on each side of the cab. The front one just has a thin rubber pad between the cab and frame. The next one back has a rubber pad and a wood block. At the back behind the seat is where the third one is located. It has a rubber pad, wood block and a spring in side the cab. You might check the tech tips. I've seen a drawing of how all this goes together somewhere. Good Luck George | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | I wil be out at my 41 soon and I'll take some pictures if you like, It should be close to the same if not the same. I looked at it the other day and I know it has springs inside the cab and blocks of wood on top of the frame. Let me know and I'll get you the pictures. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Jul 2009 Posts: 7 New Guy | | New Guy Joined: Jul 2009 Posts: 7 | I Found the information I needed in TECH TIP. pictures and all. Thanks for the help.
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Stock mount uses a spring / bolt assembly. I ended up using wood blocks with plastic shims on the back, and just shims on the front side. Also, if you are wanting to add seat belts, now is the time to drill the floor for mounts. | | |
