6 members (55shaker, Oswald, carbking, WICruiser, Phak1, 1 invisible), 43 guests, and 1 robot.
Topics128,089
Posts1,056,009
Members48,430
#609451 01/12/2010 6:23 PM
I have a 40 chevy 1/2 ton. The previous owner only bolted the front of the cab. The blocks and bolts are set in the rear of the cab, but there is something missing between the frame and the long bolts. Can anybody tell me what goes there. Picture if possible. Thanks..gp
Still crazy after all these years
1939 half ton chevy truck
gp
39nholdn #609525 01/12/2010 10:13 PM
Its been so long since I did my 39 it hard to remember. I think after your place the bolt thru the cab/block/frame there is supposed to be a spring before you put on the washer and nut. I boxed my frame so i didnt use the spring. I may be wrong but I think it was to allow a little cab movement. Hopefully somebody that has done a restoration will pipe up. I went the hotrod route.
stea #609573 01/13/2010 1:24 AM
I'm going from memory here so bare with me. I think your 40 is just like my 46. There are 3 bolts on each side of the cab. The front one just has a thin rubber pad between the cab and frame. The next one back has a rubber pad and a wood block. At the back behind the seat is where the third one is located. It has a rubber pad, wood block and a spring in side the cab.
You might check the tech tips. I've seen a drawing of how all this goes together somewhere.
Good Luck
George
46forme #609604 01/13/2010 3:07 AM
I wil be out at my 41 soon and I'll take some pictures if you like, It should be close to the same if not the same. I looked at it the other day and I know it has springs inside the cab and blocks of wood on top of the frame. Let me know and I'll get you the pictures. Dave
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
homer52 #609760 01/13/2010 6:29 PM
I Found the information I needed in TECH TIP. pictures and all. Thanks for the help.
gp
39nholdn #609822 01/13/2010 10:48 PM
Stock mount uses a spring / bolt assembly. I ended up using wood blocks with plastic shims on the back, and just shims on the front side. Also, if you are wanting to add seat belts, now is the time to drill the floor for mounts.
1940 Chevy KC 1/2-Ton
