3 members (5 Window 9434, MRMEROTH11, 1 invisible), 75 guests, and 2 robots.
Topics128,066
Posts1,055,874
Members48,428
#60967 05/27/2006 4:34 AM
Apprentice
Apprentice
I am swapping my 3 speed for a TH350. I do not know what gears are in rear end of my 65 C10. I will have TH350 rebuilt and install it myself. What are my options on getting the speedometer to be accurate. In case I need to, How difficult would it be to remove the cover on differential and find out what the gears are?
#60968 05/27/2006 5:20 AM
It would be much easier to jack up one wheel and count the driveshaft revolutions per two revolutions of the wheel.
#60969 05/27/2006 9:36 PM
Riding in the Passing Lane
It is easy to calibrate the speedo with a 350TH. Drive it on the interstate & compare the odometer reading with the mile markers. If you go like 3 miles & the odometer shows 3.3 miles remove the gear behind where the speedo cable goes in. The # of teeth is written on it. Get agear with about 2 more teeth. Less if it loses tenths.
1972 Chevy c10 Cheyenne Super
