| | | Forums66 Topics128,057 Posts1,055,810 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#60967 05/27/2006 4:34 AM | Joined: Mar 2006 Posts: 29 Apprentice | | Apprentice Joined: Mar 2006 Posts: 29 | I am swapping my 3 speed for a TH350. I do not know what gears are in rear end of my 65 C10. I will have TH350 rebuilt and install it myself. What are my options on getting the speedometer to be accurate. In case I need to, How difficult would it be to remove the cover on differential and find out what the gears are? Thanks | | |
#60968 05/27/2006 5:20 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | It would be much easier to jack up one wheel and count the driveshaft revolutions per two revolutions of the wheel. | | |
#60969 05/27/2006 9:36 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It is easy to calibrate the speedo with a 350TH. Drive it on the interstate & compare the odometer reading with the mile markers. If you go like 3 miles & the odometer shows 3.3 miles remove the gear behind where the speedo cable goes in. The # of teeth is written on it. Get agear with about 2 more teeth. Less if it loses tenths. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
