1 members (qside),
28
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 78 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 78 | picked up my '64 2ton dump truck today  looked all over the place to try and figure out what transmission is in this thing. the code on the tag on the kick panel says CL267V. I'm guessing clark?
"The Marines I have seen around the world have the cleanest bodies, the filthiest minds, the highest morale, and the lowest morals of any group of animals I have ever seen. Thank God for the United States Marine Corps!" Elanor Roosevelt
1966 c-10 stepside 1966 c-10 fleetside 1964 c-10 fleetside 1964 c-10 short bed 1964 c-30 flat bed 1964 c-60 dump truck 1968 Impala 1969 Nova 1971 Nova 1975 LUV 1976 C-30 1977 K-20 1966 SS El Camino
| | | | | Joined: Jan 2008 Posts: 4,960 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,960 | If the transmission is the one that came in the truck it would be a Clark 267V which was a relatively fast first and reverse gear and close ratio between 4th and 5th. It was made to split the first 3 gears then go from 4th low axle to 5th low axle and then back to 4th high axle and then 5th high axle. It was what was commonly referred to as a working 5th. | | | | | Joined: Jun 2009 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 45 | Chevy13man, I found a website that has your code in it. Take a look at what i found. Clark 267V 5-Speed (R)6.00:1 (1)6.06:1 (2)3.50:1 (3)1.80:1 (4)1.18:1 (5)1:1 Jeremy | | | | | Joined: Apr 2006 Posts: 78 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 78 | thanks guys. the only place I didn't look and I've been there too. any ideas on where to get manuals.
| | | | | Joined: Jan 2008 Posts: 4,960 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,960 | The 19th edition of Motor's Truck repair manual was copyrighted in 1966. It covers this transmission as well as most of the rest of your truck. They appear on eBay ever so often. | | | | | Joined: Apr 2006 Posts: 78 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 78 | found a motors 19th on ebay. I've only bought one thing on ebay so it only took me three days to get through the forgotten passwords and user names. don't try to set up a different acocunt with the same e-mail. oh no they think you're bad if you do that.
