6 members (SWEET, rfs56trk, sron48, 78buckshot, Wickedbass, JW51), 58 guests, and 1 robot.
Topics128,023
Posts1,055,367
Members48,420
#607823 01/07/2010 3:58 AM
picked up my '64 2ton dump truck today headscratch looked all over the place to try and figure out what transmission is in this thing. the code on the tag on the kick panel says CL267V. I'm guessing clark?
"The Marines I have seen around the world have the cleanest bodies, the filthiest minds, the highest morale, and the lowest morals of any group of animals I have ever seen. Thank God for the United States Marine Corps!"
Elanor Roosevelt
1966 c-10 stepside
1966 c-10 fleetside
1964 c-10 fleetside
1964 c-10 short bed
1964 c-30 flat bed
1964 c-60 dump truck
1968 Impala
1969 Nova
1971 Nova
1975 LUV
1976 C-30
1977 K-20
1966 SS El Camino
If the transmission is the one that came in the truck it would be a Clark 267V which was a relatively fast first and reverse gear and close ratio between 4th and 5th. It was made to split the first 3 gears then go from 4th low axle to 5th low axle and then back to 4th high axle and then 5th high axle. It was what was commonly referred to as a working 5th.
1 Offline
Chevy13man, I found a website that has your code in it. Take a look at what i found.
Clark 267V 5-Speed (R)6.00:1 (1)6.06:1 (2)3.50:1 (3)1.80:1 (4)1.18:1 (5)1:1
Jeremy
http://s925.photobucket.com/home/jeremy5756/allalbums
The only dumb question... is the question you didn't ask...- Unknown
thanks guys. the only place I didn't look and I've been there too. any ideas on where to get manuals.
Elanor Roosevelt
1966 c-10 stepside
1966 c-10 fleetside
1964 c-10 fleetside
1964 c-10 short bed
1964 c-30 flat bed
1968 Impala
1969 Nova
1971 Nova
1975 LUV
1976 C-30
1977 K-20
1966 SS El Camino
The 19th edition of Motor's Truck repair manual was copyrighted in 1966. It covers this transmission as well as most of the rest of your truck. They appear on eBay ever so often.
found a motors 19th on ebay. I've only bought one thing on ebay so it only took me three days to get through the forgotten passwords and user names. don't try to set up a different acocunt with the same e-mail. oh no they think you're bad if you do that.
Elanor Roosevelt
1966 c-10 stepside
1966 c-10 fleetside
1964 c-10 fleetside
1964 c-10 short bed
1964 c-30 flat bed
1968 Impala
1969 Nova
1971 Nova
1975 LUV
1976 C-30
1977 K-20
1966 SS El Camino
