6 members (moparguy, Otto Skorzeny, 2-Ton, lumbersawyer, DadsFirstPickup, Barry Martak), 149 guests, and 0 robots.
Topics128,126
Posts1,056,354
Members48,441
Anybody used a three speed floor shifter with a low hump trans cover?
I had one in my '66 C-10 once.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
No issues with clearance on the low hump?
No, it worked fine. It was just a cheap aftermarket shifter tho that I really didn't like. I ended up putting it back on the column.
If you buy a new shifter get one that is designed to fit your truck.
GMC 9500 Fan
Detroit Diesel Fan
I had one in my '65 C-10, mounted on bracket bolted where the tailshaft housing attached to the gearbox. Floor hole was off-center, but still in front of the seat.
When I put the Saginaw 4-speed in, I fabricated a plate to mount the shifter forward of the mount points on the trans, so I only had to enlarge the floor hole a little. Also, some tricky bending of the very short shift rods.
I've seen aftermarket kits for converting column shift to floor shift, Hurst I think.
Good luck.
cm
If you can't fix it with a hammer and screwdriver, you need a bigger hammer.
1965 Chevy C10
