4 members (Fannin, Phak1, TUTS 59, 1 invisible),
180
Mod | | | Forums66 Topics128,084 Posts1,056,085 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2003 Posts: 218 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 218 | Anybody used a three speed floor shifter with a low hump trans cover? | | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | I had one in my '66 C-10 once.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
| | | | | Joined: Feb 2003 Posts: 218 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 218 | No issues with clearance on the low hump? | | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | No, it worked fine. It was just a cheap aftermarket shifter tho that I really didn't like. I ended up putting it back on the column.
If you buy a new shifter get one that is designed to fit your truck.
| | | | | Joined: Dec 2008 Posts: 319 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 319 | I had one in my '65 C-10, mounted on bracket bolted where the tailshaft housing attached to the gearbox. Floor hole was off-center, but still in front of the seat. When I put the Saginaw 4-speed in, I fabricated a plate to mount the shifter forward of the mount points on the trans, so I only had to enlarge the floor hole a little. Also, some tricky bending of the very short shift rods. I've seen aftermarket kits for converting column shift to floor shift, Hurst I think. Good luck. cm If you can't fix it with a hammer and screwdriver, you need a bigger hammer.1965 Chevy C10 | | |
