1 members (baldeagle), 158 guests, and 2 robots.
Topics128,110
Posts1,056,241
Members48,437
#603957 12/24/2009 3:07 AM
I'm finally at the point where I can start putting my new engine / driveline back in the truck. Its been so long since I took it all apart, I can't remember what gaskets go between the engine and the dif.
I think there was a gasket between the transmission and the driveshaft, but other than that I don't know. The assembly manual doesn't show any gaskets listed.
I tried searching, but everything was for the 1/2ton, nothing for the 3/4 '53 like mine.
I really should have kept track of all that..oops
Alright, I've been scouring my notes again and it looks like there is indeed a gasket/seal between the transmission and the torque tube. I can't seem to find a product # anywhere. Does anyone know where I can get one?
If this is the joint that you’re talking about Fern, then yes, there are a series of gaskets/shims that adjust the friction that the cork seal ring applies to the ball.
http://www.pbase.com/dennygraham/image/120571518/large
http://www.pbase.com/dennygraham/image/120571523/large
They are available from all of the vendors in a set. The instructions for adjusting them are in the Chevrolet Truck Shop Manual.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Thanks Denny. I don't know how I missed that section in the repair manual. American classic lists a gasket set(GKT-04) for 1/2ton, and a different (GKT-05) for the long beds. The book only mentions a cork gasket and some shims, what are the extra gaskets for??
http://americanclassic.com/asp/dync...&iyear=1953&ytype=to&exyear=
Either way, is this something napa would have? I just got an order from classic, and I really don't want to place an order for 1 thing dang .
The gaskets are the shims, you put as many in as it takes to get a firm but free movement of the ball after you tighten up the flange. If it's to tight you add a shim if it's to loose and falls down you remove a shim. It's explained in the manual.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
No, I doubt if Napa or any of the auto parts would still carry them. I'm sure there is something that you need for the truck, there is alway a few parts that you can think of to fill in an order and make the shipping worth while. Try to find a buddy with a Stovebolt and split the shipping.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
I found the gaskets at NAPA, felpro es72843. Took a few days to come in, but it only costed $12.
For anyone that may need this info in the future, the kit included:
1-universal joint packing
4-universal ball collar
1-universal joint ball collar
4-universal joint retainer shim
now for a question, to put the cork seal on, do I have to remove the support on the other side of the shaft? I can't imagine the cork having a whole lot of stretch and fit over the ball.
I looked through your pictures Denny, you make it look too easy.
Yep, afraid you do have to remove the center support to get the cork on. Here is a picture that should show it pretty clearly. A little liquid dishwashing soap works wonders on the rubber to metal contacts.
http://www.pbase.com/dennygraham/image/121008098/large
Thanks for the FelPro part numbers, I'll add that to my folder. I'm surprised that NAPA had them but that's a good tip, the price is the same as the catalog vendors but they tap you for another ten bucks S&H.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Alright, now I have another question. I can't seem to get the nut holding the front yoke on off. What is the factory torque spec for it? I can't seem to find it in the shop manual.
Use a impact wrench that has lots of power. It will jar it loose and trying to do it by hand is almost impossible.
