1 members (baldeagle),
158
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 256 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 256 | I'm finally at the point where I can start putting my new engine / driveline back in the truck. Its been so long since I took it all apart, I can't remember what gaskets go between the engine and the dif.
I think there was a gasket between the transmission and the driveshaft, but other than that I don't know. The assembly manual doesn't show any gaskets listed.
I tried searching, but everything was for the 1/2ton, nothing for the 3/4 '53 like mine.
I really should have kept track of all that..oops | | | | | Joined: Jan 2009 Posts: 256 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 256 | Alright, I've been scouring my notes again and it looks like there is indeed a gasket/seal between the transmission and the torque tube. I can't seem to find a product # anywhere. Does anyone know where I can get one? | | | | | Joined: Jan 2009 Posts: 256 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 256 | Thanks Denny. I don't know how I missed that section in the repair manual. American classic lists a gasket set(GKT-04) for 1/2ton, and a different (GKT-05) for the long beds. The book only mentions a cork gasket and some shims, what are the extra gaskets for?? http://americanclassic.com/asp/dync...&iyear=1953&ytype=to&exyear=Either way, is this something napa would have? I just got an order from classic, and I really don't want to place an order for 1 thing  . | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | The gaskets are the shims, you put as many in as it takes to get a firm but free movement of the ball after you tighten up the flange. If it's to tight you add a shim if it's to loose and falls down you remove a shim. It's explained in the manual. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | The gaskets are the shims, you put as many in as it takes to get a firm but free movement of the ball after you tighten up the flange. If it's to tight you add a shim if it's to loose and falls down you remove a shim. It's explained in the manual. No, I doubt if Napa or any of the auto parts would still carry them. I'm sure there is something that you need for the truck, there is alway a few parts that you can think of to fill in an order and make the shipping worth while. Try to find a buddy with a Stovebolt and split the shipping. Denny Graham Sandwich, IL
| | | | | Joined: Jan 2009 Posts: 256 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 256 | I found the gaskets at NAPA, felpro es72843. Took a few days to come in, but it only costed $12.
For anyone that may need this info in the future, the kit included: 1-universal joint packing 4-universal ball collar 1-universal joint ball collar 4-universal joint retainer shim
now for a question, to put the cork seal on, do I have to remove the support on the other side of the shaft? I can't imagine the cork having a whole lot of stretch and fit over the ball.
I looked through your pictures Denny, you make it look too easy. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yep, afraid you do have to remove the center support to get the cork on. Here is a picture that should show it pretty clearly. A little liquid dishwashing soap works wonders on the rubber to metal contacts. http://www.pbase.com/dennygraham/image/121008098/large Thanks for the FelPro part numbers, I'll add that to my folder. I'm surprised that NAPA had them but that's a good tip, the price is the same as the catalog vendors but they tap you for another ten bucks S&H. Denny Graham Sandwich, IL
| | | | | Joined: Jan 2009 Posts: 256 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 256 | Alright, now I have another question. I can't seem to get the nut holding the front yoke on off. What is the factory torque spec for it? I can't seem to find it in the shop manual. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Use a impact wrench that has lots of power. It will jar it loose and trying to do it by hand is almost impossible. | | |
