7 members (55shaker, Woodcmiami, Rusted Nut, Gdads51, CuzzFuzz, Still At It, 1 invisible),
156
Mod | | | Forums66 Topics128,138 Posts1,056,441 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 121 | hey there.i just got a new door lock and keys and tried to take the old lock out but got stuck.i removed the 3 screws that hold the latch in place, and i removed the door handle, but i cant get the thing out.it wiggles a lot but the last thing holding it in is the arm from the latch to the inside handle.im not sure how to get the sucker off.vice grips wont seem to hold on and turn it.all i want to do is put a new door lock/key in. ANY SUGGESTIONS?
Thanks, Dan
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The lock is held in place by a clip accessible from the rear edge of the door under the weatherstrip. You don't need to remove the handle or the latch. | | | | | Joined: Apr 2009 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 121 | alright, i know which clip you are talking about.if im looking at the clip from the inside side, which way does it move.or does it matter? what part of the door do i get to it from,do i have the window down to get to it? im confused as to how i get to it.
Thanks, dan | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Pry it aft a little with a screwdriver then grab it with pliers and continue pulling aft. | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | There's a really good picture of the setup in Chap 1 of the shop manual.
Ed
