8 members (tclederman, Hotrod Lincoln, ChevyBlue, moparguy, mk72, farmallb, Opelika Tom, Otto Skorzeny),
179
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 121 | just wondering about locking my driver side door.i push the handle down and it locks, but when i close the door, it unlocks it.but if i lock it before i close it, it stays locked.i just have to get out through the passenger side.is this normal?any adjustment here to fix that?...... and, why is the key on the passenger side, but not the driver side.wheres the logic on that one.just curious.
thanks, dan | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy dantheman49-6400, the story I learned was that people smarter than the average bear determined it was safer to lock the drivers door from the inside, and then slide across the seat and out the passenger door which you can lock from the outside with a key. This means you must enter the locked truck from the safety of the sidewalk or the safe side of the road, and that you exited the truck onto the sidewalk or the safe side of the road, and in doing so were in less danger of injury, hope that helps. | | | | | Joined: Apr 2009 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 121 | haha.that helps.pretty funny.thanks 3B
Dan | | |
