7 members (JW51, Hotrod Lincoln, Wally / Montana, texas46, TooMany2count, Jaison, 1 invisible), 120 guests, and 2 robots.
Topics128,082
Posts1,055,961
Members48,430
just wondering about locking my driver side door.i push the handle down and it locks, but when i close the door, it unlocks it.but if i lock it before i close it, it stays locked.i just have to get out through the passenger side.is this normal?any adjustment here to fix that?...... and, why is the key on the passenger side, but not the driver side.wheres the logic on that one.just curious.
thanks,
dan
3B Offline
Hy dantheman49-6400, the story I learned was that people smarter than the average bear determined it was safer to lock the drivers door from the inside, and then slide across the seat and out the passenger door which you can lock from the outside with a key. This means you must enter the locked truck from the safety of the sidewalk or the safe side of the road, and that you exited the truck onto the sidewalk or the safe side of the road, and in doing so were in less danger of injury, hope that helps.
haha.that helps.pretty funny.thanks 3B
Dan
