0 members (),
79
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 33 | Other than difference in the driveshaft, will everything from my 55 1st bolt on a 48/49 frame? Thanks,Zach.
- Zach Morris
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | No.
The pre-'48 frame has a higher kick-up over the rear axle. You'll have a problem mounting the bed on the earlier frame. I've seen it done and it was real ugly!
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jan 2007 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 33 | Ok thanks, but its a 48 or a maybe a 49 chassis so its not a pre 48 frame? I might be 100% wrong, but i thought 47-54 frames where pretty much identical, than the 55 1st obviously has the open driveshaft?
- Zach Morris
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I think that OldSub meant: "The pre-'54 frame has a higher kick-up over the rear axle."
The 1/2 ton 54/55 A-D frame is different from earlier A-D frames (causing the problem described by OldSub).
| | | | | Joined: Jan 2007 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 33 | Oh ok....well if im just going for a rat rod appearance, how difficult would it be and how bad would it look?
- Zach Morris
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I think that OldSub meant: "The pre-'54 frame has a higher kick-up over the rear axle."
The 1/2 ton 54/55 A-D frame is different from earlier A-D frames (causing the problem described by OldSub). Tim is of course correct, I screwed up that answer. Sorry.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Oh ok....well if im just going for a rat rod appearance, how difficult would it be and how bad would it look? That's not enough information to answer the question. If you are going to z the frame and channel the bed it no longer matters at all. If you want to retain the bed in a stock location you have a challenge. Once you abandon a stock look most anything is possible with enough time and money. But its best to have a very clear idea where you're headed before you start cutting and welding.
