6 members (baldeagle, Lightholder's Dad, Christian, Wickedbass, NJC, Hotrod Lincoln), 63 guests, and 4 robots.
Topics128,017
Posts1,055,338
Members48,419
#608735 01/10/2010 6:07 AM
Im looking at a 1953 1 ton flatbed and i was wanting to know if there is a difference between 1/2 ton and 3/4 ton cabs and the 1 tons and up.
scoper27 #608739 01/10/2010 6:16 AM
Cab is the same 1/2 through 2 ton, exept for LCF. The differenc is in the front end sheetmetal. 1/2 through 1 tons use the smae front end body parts, 1.5 ton and larger are wider and longer.
Bill Burmeister
scoper27 #608740 01/10/2010 6:16 AM
cabs are the same (COE cabs are different)
tclederman #608742 01/10/2010 6:25 AM
The fenders are bigger on the 1 tons and up right.
scoper27 #608747 01/10/2010 6:46 AM
No, fenders are larger on those bigger than 1-ton. The 1-ton has the same fenders, hood and grill as the smaller truck.
