3 members (Danielbolt, bluechev, 1 invisible), 104 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,456
I have a '67 GMC pickup with a 250 and a 3 speed column shift. I'm wanting to put an automatic in it, but I don't care anything about bumping up to another engine.
I had a couple of people tell me today that a 350 turbo is the way to go, but I have a problem! My starter bolts around the nosecone to the transmission via 3 bolts. The 350 turbo would require the starter to bolt to the block.
Is there any autos out there that have the mounting surface for my starter, or do I have to swap all or nothing?
1939 Chevy 1/2 ton AKA Light Delivery.
1967 GMC 1/2 ton short-step.
try buffalo enterprises. they make adapter plates for that purpose. you will also need a flexplate flywheel.
buffalo's contact:
25625 Dahl Road, Arlington, WA, 98223
(360) 652-7684
Riding in the Passing Lane
Have you looked at your block? It seems it would be drilled for the bolts comeing up from the bottom.
1972 Chevy c10 Cheyenne Super
Welcome to the 'bolt Robert!
I seem to recall powerglides being placed behind 250 cu.in. engines. Would you consider a 'glide?
Phil
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
I believe a TH 350 will bolt up, if the truck came with an automatic the starter would've had to bolt to the block, you'll need a starter and flex plate for a 250 6cyl with automatic. As Wrenchbender said, the bolt holes should be there.
Keith
If it were easy they'd have grade schoolers doing it!
Well, you guys were right! Once I dug through the grease, I found a hole! (didn't pull the starter to look for hole #2, but it's probably there too) I never would have thought that starters had dual mount - depending on transmission.
Thanks for the info...I didn't want to have to swap motors as well. Some people think I'm goofy for not dropping a 350 in the truck, but at this point I'm perfectly content with the output of the 250.
Quote
Phil
I don't know anything about them, other than they are 2 speed. I may be wrong, but I figured if you split it into 3 and went with a th350 then you'd have better low end as well as a lower highway rpm. (like I said though, don't know nuthin 'bout 'em! Maybe the ratio is different than what I'd expect.)
Both the Powerglide and the TH350 have direct as the final or top gear same as the stock 3-speed.
Years ago I had a '66 that had a Powerglide and it seemed to work pretty well, but it was a 327.
Today I have a '72 with a TH350 and a 350 and it drives pretty nice.
The Powerglide would use a little less power and if I remember right weighs slightly less than the TH350. That might have some performance advantage with the smaller motor, but I doubt it makes enough difference to matter.
Quote
I guess that means I've got some low gears then! This 250 sounds like she's winding pretty tight when I get up over 60mph!
Did they normally put low gears in with the 250/3 speed combo, or were most of them geared low no matter what combo?
Find out what your rear end ratio is. 3:90 or 3:73 you may want to put a 700-4r auto o-drive. If it,s higher than that (lower number) use the 350TH.
most all 250 with three on the tree had a 3:73 rear gear.
super250six
