| | | Forums66 Topics128,148 Posts1,056,810 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 12 New Guy | | New Guy Joined: Sep 2007 Posts: 12 | Just replaced the rear with a 12 bolt from a Firebird. It is hanging in the springs with the new mounting brackets welded on but no shocks yet. the springs sure seam to have a lot of lateral movement. Do I need to install a panhard bar to make it solid? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The original rear end had pivots on the rear springs. You have to get the pinion angle correct & weld them solid. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2007 Posts: 12 New Guy | | New Guy Joined: Sep 2007 Posts: 12 | I did that and the rear end is bolted solidly to the springs. The problem is that thentire unit springs and housing move side to side. | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Original/stock springs? Have you checked the spring bushings? If they're worn out that will allow some movement. I would replace "all" bushings. | | | | | Joined: Sep 2007 Posts: 12 New Guy | | New Guy Joined: Sep 2007 Posts: 12 | Thanks Wrench. I guess I should replace the bushings. I was just curious whether there was anything I was missing. | | |
