5 members (Peggy M, Hotrod Lincoln, Gdads51, mick53, 2-Ton), 132 guests, and 4 robots.
Topics128,165
Posts1,056,989
Members48,458
Just replaced the rear with a 12 bolt from a Firebird. It is hanging in the springs with the new mounting brackets welded on but no shocks yet. the springs sure seam to have a lot of lateral movement. Do I need to install a panhard bar to make it solid?
Riding in the Passing Lane
The original rear end had pivots on the rear springs. You have to get the pinion angle correct & weld them solid.
1972 Chevy c10 Cheyenne Super
I did that and the rear end is bolted solidly to the springs. The problem is that thentire unit springs and housing move side to side.
Y
Y Offline
Original/stock springs? Have you checked the spring bushings? If they're worn out that will allow some movement. I would replace "all" bushings.
Thanks Wrench. I guess I should replace the bushings. I was just curious whether there was anything I was missing.
