4 members (Steelonsteel, FishinToms53, Gdads51, 1 invisible), 126 guests, and 3 robots.
Topics128,045
Posts1,055,528
Members48,424
#608596 01/09/2010 11:20 PM
Other than difference in the driveshaft, will everything from my 55 1st bolt on a 48/49 frame? Thanks,Zach.
- Zach Morris
No.
The pre-'48 frame has a higher kick-up over the rear axle. You'll have a problem mounting the bed on the earlier frame. I've seen it done and it was real ugly!
Ok thanks, but its a 48 or a maybe a 49 chassis so its not a pre 48 frame? I might be 100% wrong, but i thought 47-54 frames where pretty much identical, than the 55 1st obviously has the open driveshaft?
- Zach Morris
I think that OldSub meant: "The pre-'54 frame has a higher kick-up over the rear axle."
The 1/2 ton 54/55 A-D frame is different from earlier A-D frames (causing the problem described by OldSub).
Oh ok....well if im just going for a rat rod appearance, how difficult would it be and how bad would it look?
- Zach Morris
Tim is of course correct, I screwed up that answer. Sorry.
That's not enough information to answer the question.
If you are going to z the frame and channel the bed it no longer matters at all. If you want to retain the bed in a stock location you have a challenge.
Once you abandon a stock look most anything is possible with enough time and money. But its best to have a very clear idea where you're headed before you start cutting and welding.
