1 members (JW51),
151
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,113 Posts1,056,279 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 293 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 293 | I am wondering about using a lump head kit on my 250ci engine. The engine will have aftermarket exhaust and intake and TBI EFI. Can I install these lumps myself? I have watched a video on YouTube, it seems straighforward, but... I have already swapped engine, installed a blower, swapped trans, but never actually worked inside an engine. What are the possibilities of screwing up? How useful are the lumps on an otherwise internally stock engine, does it require a camshaft? The truck is a daily driver, I like low to mid range torque. Thanks for the inputs!
'57 Chevy Suburban; '70 Chevy Impala.
| | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i'm no expert here but seems like a lot of trouble for a low range torque daily driver. i mean i guess you'll always have a lump port head when your done. you are going to have the head redone with larger valves while it's out right? i would say it depend on what kind whether you can do it yourself. are they the cement in style or bolt in style with the boss removed? i personally would install a higher lift cam before the lump ports, but i have never done a lump port head so..... try it and let us know! can't wait to see what everyone else says. i want to do one for my 292 some day. | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | oh forgot to say, you won't really be working on the inside of the engine will you, just the head right? i mean if you do screw it up just get another head. how many miles are on this one? | | | | | Joined: Sep 2008 Posts: 293 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 293 | Thanks for the input! I had never heard about glue-in lumps, I only know about the screw-in type. What is best, who makes which ones? While the head is out, what are you guys' thoughts about milling the head a bit for more compression (still running regular)? And how much?
| | | | | Joined: Feb 2000 Posts: 5,219 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,219 | I would think with a blower, lumps would not be needed. Have you ever seen the head on turbo charged diesel? They have crappy looking ports, but the turbo just forces the air in anyway, your blower should do the same thing. You need larger valves and port work to go along with the lumps or else they don't work. The added benefit of higher air flow will allow a larger cam to work better so install one of those while you are add it. What about the exhaust? Do you have headers of some sort? Have you been to the ( www.inliners.org )site and read all the DYNO results from the 292 tests that were run? You might have to pay for them, but it would be worth reading before getting in to your head. Joe | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | thanks, you peaked my interest and i watched those youtube videos. pretty interesting. i haven't thought about lump port heads in several years. i used to be on the inliners site but my password stoped working one day and i couldn't log in. i hope i wasn't kicked off. hahaha. i sure learned a lot there and need to check my password again. i would def try this before i have the head done just in case you make a mistake. i have a mill so that would make it a little easier. it def looks doable for the average individual. the lump retention bolt makes it look like it could be easy to do. years ago i read about some being brazed in or like epoxyed in. i guess it would take away the chance for a crack where you drill that new hole. i don't know which is better. ggod luck let us know if it works well.
| | | | | Joined: Sep 2008 Posts: 293 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 293 | A little precision, the blower mounting I mention in the original post was not mounted on that engine, it was just to give you guys an idea of mechanical stuff I have already done in my life, to judge my abilities. Thanks, keep the input coming!
| | | | | Joined: Feb 2000 Posts: 5,219 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,219 | I ran a 250 with epoxy in the ports for a couple of years with no problems (with the epoxy). I made the mistake of going with bigger exhaust valves and keeping the stock intake valves. Using our flow bench I was able to gain quite a bit of exhaust flow and some intake (about 10%). The intake was mostly low lift flow which should provide good of idle and midrange torque. It ran really good under full throttle and off idle, the problem came in at mid range, like pulling a long hill where the throttle is open quite a bit. The exhaust pulses would pull so hard, the intake charge was being pulled right on through, causing extreme lean out. Simply letting off some or going full throttle would bring it out of the lean condition. I tried for two years to cure the problem, I finally replaced the head with a stock rebuild and the problem went away.
Some day I will install bigger valves in the intake and try again. The lumps direct the air up and over the flat floors so it enters the valve opening at a better angle. My epoxy does the same thing. I left the bolt boss in place, so that wasn't helping either. You loose so much port volume with the lumps, it takes removing the boss to gain back what you loose. That was probably hurting my head as well, but I just couldn't get myself talked into cutting them out. Dad and I have seen heads ruined by opening them up to much, and I just didn't what that to happen.
Joe | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | why not log onto Inliners and ask Larry directly about his lump port kit or http://www.t6racing.org/
