2 members (Guitplayer, MickeyP), 70 guests, and 2 robots.
Topics128,021
Posts1,055,356
Members48,420
#608500 01/09/2010 5:02 PM
I just bought a 1959 Apache and the throttle cable is not connected. Does anyone have or know where I can find something that show how to connect the manual throttle and choke?
GeneBrownlow #608527 01/09/2010 7:38 PM
Hey Gene, Welcome to the Bolt! Glad to see another Task Force owner join us.
If you do not already have a Shop Manuel or an Assembly Manuel for your truck then I suggest investing in one soon, they are invaluable in fixing and troubleshooting things. As to your throttle cable, there should be a bracket on your carb, screwed to the top of the Air horn. The bracket will have two clamps on it, one for the choke and one for the throttle. the throttle cable in clamped in there and run to the throttle linkage where it threads through a hole and has a little clamp type screw on it that allows the throttle to still slide up for acceleration.
For some reason I can post the link to the Manuel on Old Car Manuel Project.com for a visual. Hopefully someone will come along with an illustration. Good Luck!
58' 3200 235 3-speed/OD
GeneBrownlow #608529 01/09/2010 7:44 PM
Riding in the Passing Lane
I take it this is a 6 cyl. Your carb should have a bracket that the cables hook to. The throttle is vertical & the cable core goes into the hole in the rod with cable stop underneath. The choke cable is horozontal & the core hooks into the connector on the carb with the set screw. This is about the best I can explain it. Maybe someone will come in with photo.s.
1972 Chevy c10 Cheyenne Super
Someone has previously linked to a picture. You might find it using search.
Cletis #608675 01/10/2010 3:02 AM
He probably heard you the first time cletis ... smile
