2 members (Nick in Manitou, klhansen), 77 guests, and 3 robots.
Topics128,080
Posts1,056,315
Members48,442
Apprentice
Apprentice
I am going to remove the standard 3 speed and install a TH350. The flex plates avaiable for small blocks (mine is a 350) seem to be offered in two versions. 153 and 168 tooth are the choices. How do I know which one to choose?
Donny
Either flexplate will work. The biggest deal is the starter. Look at your block and see what pattern the starter mounting bolts have: stright-across or diagonal. Many blocks have 3 holes so that you can use either one, but if only 2 of the holes are tapped, then you'll need to get a flexplate that will work with your starter.
If the bolts are in the "straight-across" pattern, the 153-tooth flexplate will fit. If they're in the diagonal pattern, the 168 works.
Apprentice
Apprentice
Thanks Ray. Just what I needed. I have been browsing your site in the last week or so. I like it. It is very interesting. Thanks for the answer and sharing your site.
Donny.
