Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (3B, Gdads51, Otto Skorzeny, 1 invisible), 93 guests, and 4 robots.
Topics128,281
Posts1,058,472
Members48,490
#606416 01/02/2010 6:06 AM
hi guys i hope u can help i have just restored my 63 and am needing oem or other inner wheel wells (not inner fender) something to protect the leading edge of the doors inside the fenders if there is such a thing someone must have come up with something to this obvious oversite by gm
Never heard of anything OEM. I believe you would have to custom make something. My way of dealing with it is to put a protective coating on there. Something that would protect the metal while still looking original.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
Ive got a 63 that has these wells from the factory. There is an inner fender, outer fender, and then I have a "fender" that goes between the two. It has to be removed to get access to the side emblems on the fender, but I cannot locate any replacements.
http://s971.photobucket.com/albums/ae197/jon63c10
1963 c-10 shortbed stepside 427 BBC T16 HD 3 speed
1963 c-10 shortbed fleetside 348 "w" 1st gen big block & powerglide
jon1963 #611199 01/19/2010 12:11 AM
Factory front fenders have an extension piece with a rubber flap factory-stapled to it, to keep road debis from kicking up into the front face of the door. Perhaps your front fenders don't have them installed. Is this the case? Otherwise, there is no other intermediate fender that goes between the two, that is OEM or factory.
thanks ill try the rubber flaps
