0 members (), 182 guests, and 1 robot.
Topics128,108
Posts1,056,228
Members48,436
#608295 01/08/2010 10:16 PM
I have a front axle on my '52 3100 that I believe is from a sedan.It has bendix brakes and ball bearings, and I'm looking to upgrade the bearings. The axle stamping # is 656172GM. Can anyone ID the source of the axle? Are 3100 and sedan bearings the same? Do any of you bolters have a set of current #'s for the bearings?
tools94 #608301 01/08/2010 10:37 PM
I think most any of the repro parts suppliers have the roller bearing available although didn't see them in Jim Carters catalog. The Brothers, The Truck Shop, etc.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
53moneypit #608309 01/08/2010 10:52 PM
Are these roller bearing replacements available locally? Die anyone note the maker and number? Are they made by one of the national bearing companys so we could get them at either a FLAPS or bearing warehouse?
That would be nice
Dennis
oldbluetruck #608326 01/08/2010 11:26 PM
Does your axle look like one of these? If so, you should be able to look up parts in this book.
tclederman #608360 01/09/2010 12:58 AM
I don't think there was a Chev sedan front axle with Bendix brakes. They had indepensent suspension long before the 50s.
1951 1 Ton Completed
truckernix #608478 01/09/2010 2:43 PM
I Think I have a truck axle after all, Myt axle does not look like the sedan photo supplied by Tim, and goes along with Truckernix's and thw independent suspension theory. I did come up with an application that used Chicago Rawhide's #'s of B52 for the inner and B01 for the outer, now I'll see if I can't interchange to an SKF or National number. Thanks for the assist!
