2 members (NorCal52Suburban, DaveV), 84 guests, and 6 robots.
Topics128,187
Posts1,057,211
Members48,465
Help! Any opinions,sugesttion? Manual choke and manual throttle. Thanks
Rochester Model B
GMC: Get More Cash...
1958 GMC
My Webshots photos
Carter YF, model 2100S. Make sure it is the GM version, the ford version is jetted way too rich.
Bill Burmeister
Having had both the B and the YF, I second Longbox55's recommendation. Just my personal experience.
V
V Offline
My Rochester Model B continues to leak... I still use it but it is a pain in the rear. I recommend that you take the time to consider the long term problems with the B.
Riding in the Passing Lane
Around 60 up they reinfoced the neck On the model B to stop the leakage problems & put a built in filter. They are easily available & easy to rebuild.
1972 Chevy c10 Cheyenne Super
The later Model B might be better, but I can speak from experience that the early ones are very prone to both float bowl cracks and base warpage.
Bill Burmeister
Back in the 40's and 50's, there was an advertising slogan- - - - - -"The ABC's of carburetion- - - -Always Buy Carter" Some things never change!
grin
I'll admit, I do have Holleys on mine, though. Model 1904s sourced from Internationals.
Bill Burmeister
