| | | Forums66 Topics128,179 Posts1,057,157 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 95 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 95 | Help! Any opinions,sugesttion? Manual choke and manual throttle. Thanks | | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Carter YF, model 2100S. Make sure it is the GM version, the ford version is jetted way too rich.
Bill Burmeister | | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | Having had both the B and the YF, I second Longbox55's recommendation. Just my personal experience.
Bill | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | My Rochester Model B continues to leak... I still use it but it is a pain in the rear. I recommend that you take the time to consider the long term problems with the B. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Around 60 up they reinfoced the neck On the model B to stop the leakage problems & put a built in filter. They are easily available & easy to rebuild. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The later Model B might be better, but I can speak from experience that the early ones are very prone to both float bowl cracks and base warpage.
Bill Burmeister | | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | Back in the 40's and 50's, there was an advertising slogan- - - - - -"The ABC's of carburetion- - - -Always Buy Carter" Some things never change! Jerry
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | "The ABC's of carburetion- - - -Always Buy Carter"  I'll admit, I do have Holleys on mine, though. Model 1904s sourced from Internationals.
