9 members (JoergK., Bill Hanlon, J Lucas, Chip O, dt235sd, Gdads51, Hotrod Lincoln, 2 invisible),
75
0
Mod | | | Forums66 Topics128,205 Posts1,057,427 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#60783 05/23/2006 4:42 AM | Joined: Jul 2005 Posts: 52 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 52 | Can anyone please tell me how many teeth are on a later 235 flywheel? I have a 55 235.
Tomorrow I need to climb under my truck & count the teeth to match it up with the proper bendix on the starter.
I think it may be a total of 168.
Can someone confirm this?
If so can someone tell me how many teeth in maybe 12" to make it easier to count?
Thank you for the help. | | |
#60784 05/23/2006 1:29 PM | Joined: Oct 2003 Posts: 363 Member | | Member Joined: Oct 2003 Posts: 363 | A search of the archives clears things like this up quickly; however it was common practice to use the old flywheel with a new engine, so make sure you count.
139 tooth early
168 tooth late | | |
#60785 05/23/2006 11:35 PM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | The difference is, however, the early flywheel will work with a 6 volt starter, which can be run with 12 volts, and the late flywheel is for a 12 volt starter. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
