6 members (Oldpickupman, klhansen, 55shaker, TUTS 59, Quindel54, jay d), 119 guests, and 2 robots.
Topics128,195
Posts1,057,377
Members48,469
Can anyone please tell me how many teeth are on a later 235 flywheel? I have a 55 235.
Tomorrow I need to climb under my truck & count the teeth to match it up with the proper bendix on the starter.
I think it may be a total of 168.
Can someone confirm this?
If so can someone tell me how many teeth in maybe 12" to make it easier to count?
Thank you for the help.
A search of the archives clears things like this up quickly; however it was common practice to use the old flywheel with a new engine, so make sure you count.
139 tooth early
168 tooth late
The difference is, however, the early flywheel will work with a 6 volt starter, which can be run with 12 volts, and the late flywheel is for a 12 volt starter.
Joe smile
