1 members (klhansen),
101
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,151 Posts1,056,999 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 105 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 105 | I found a 5 lug rearend out of a 60 to 62 1/2 ton pickup. It has the 3:73 ratio. Will a 4speed tyranny from a 66 that is behind a 250 match up to my 235? I also have a tranny from 64 that has a 230 motor. The one behind the 250 has been rebuilt. What kind of highway speed can I expect with that setup? I also have access to a 6 lug Adelaide but he is not sure of the deadens ratio on it. ( same years) | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Do you mean 6 lug? Chev used 6 lug on 1/2 tons up 1970.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2009 Posts: 105 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 105 | He said 5 lug so not sure. All he deals in is 60 thru 66 and he said it is a factory rearend. I would rather stick with 6 so as not to have to buy new wheels but not sure yet wanting to open up the rear end and get a little better speed with out breaking the bank and keeping the engine rpms down | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Factory 5-lug started in '71. Either he is confused or that's not a '60 to '62 factory axle.
The 6-lug coil sprung axles up until '70 should be good options for you.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Oct 2009 Posts: 105 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 105 | What gear ratio would they be and can I put either of the trannys I mentioned,in with having to Much trouble. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | The two transmissions you mention should be the same, both SM420's. If one is something different its because someone has done some swapping.
I don't know the ratios available in those rears but someplace like Randy's Ring and Pinion will give you both a listing of available ratios and a calculator to determine speed.
