3 members (cmayna, KEVINSKI, IHPWR), 144 guests, and 4 robots.
Topics128,148
Posts1,056,810
Members48,454
Hi all,
I need to wire a 49 burb and was wondering if you could help with a shopping list. Here's what I have so far. I am leaning towards wiring to original because I want the look of original buttons and switches, and most of the 12-20 circuit wiring kits comes with a lot of stuff I probably won't use. It's a 261 6 cylinder with 12V alt, floor starter going into it. Here's what I have so far (starting with nothing).
Original harness from classicparts
dimmer switch
turn signal stat
headlight switch
cig lighter
guages
ignition switch
Where can I get the original fuse panel, or can I? What about terminal blocks, how many?
Thanks in advance.
Patrick
Ok, so I got smart. classicparts sells a wiring diagram for 4.50. I just ordered one. I can make my list from that :-)
does yours have a fuse block on it if it does you may need to clean it up and reuse it terminal blocks og is the 3 but i use the 4 and add in my turn signal take a look at my link below and go to photos also you can get the the terminal blocks for arounnd 9 to 10 bucks each you need 2 of them go to the truckcarshop.com if not google it there in California and do ship if i can hel shoot me an email Godd Luck Roy God Bless
I REWIRING 6V & 12V, CUSTOM STEREO SYSTEMS
MAY GOD BLESS YOU AND YOUR FAMILY ALWAYS. HE IS GOOD ALL THE TIME!!!
www.SoCalConcepts.webs.com
On my 49 there are 5 fuses in the fuse box. I have rewired most of the truck using good wire and connectors from FLAPS. I am still using the generator so cannot comment on how to wire an alternator.
The wire gauge required is or should be shown on the wiring diagram. Because it is a diagram for a 6 volt system you can get away with light gauge wire if need be.
The most important thing is to use a good crimping tool and make good connections. Give them a 'tug' test before you install them.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
