3 members (TUTS 59, Phak1, WICruiser), 122 guests, and 2 robots.
Topics128,091
Posts1,056,445
Members48,443
#60728 05/22/2006 7:27 AM
What is the consensus for a dual exhaust setup on a stovebolt street machine? That is... what size pipes to use? Is it necessary to run x pipes to equalize? I was planning on using 2 1/2 inch pipes... same as the headers, but I am leaning towards 2 inch pipes now.
Aplication will be a 302 in a 1940 gmc.
I am also interested in how a setup should look... staight out the back, before the rear wheels, after the rear wheels, etc.
Any tips and links would be appreciated.
#60729 05/22/2006 1:01 PM
#60730 05/22/2006 1:25 PM
i am running 2 inch and i was told that is the largest i should run because you need some back pressure. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
#60731 05/22/2006 2:11 PM
Riding in the Passing Lane
I agree. 2-2 1/4 would be plenty large enough. The exit area is your own taste. I like em coming out the rear with crome tips. If it is a panel you should exit out the sides.
1972 Chevy c10 Cheyenne Super
#60732 05/22/2006 5:14 PM
It depends on the engine- I've got a 261 in mine and am running 2" from the Fentons til they 'y' together and a straight 2 1/2 from there back.
#60733 05/24/2006 11:52 PM
Z
Z Offline
I am running a 302 (ford) in my 46 and have 2" pipes straight back.
exhuast
1946 Chevy Pickip
#60734 05/25/2006 12:10 AM
Zipper
My 302 is a gmc 6 banger. Cool pic! I'm sure it has a nice exhaust note with those glass packs.
#60735 05/26/2006 12:03 AM
Z
Z Offline
thanks bigbad.
I am going to just weld on some ss 2" straight tips so the exhaust comes straight out the back directly under the bumper.
It sounds really nice with glasspacks...not too loud but if you really get on it they bark pretty good.
1946 Chevy Pickip
#60736 05/26/2006 2:35 PM
I'm w/ NM
I have the same set up on a 292 off a set of langdons 3+3. 2 ~ 2'' to a single muff and 2-1/4'' out
Jim & Caroline
