2 members (Peggy M, MNSmith),
240
Mod | | | Forums66 Topics128,282 Posts1,058,495 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 24 | I am working on a 54 1/2 Chevy 6400 big truck. Trying to find out if the engine is a 216, 235 or 261. The engine code is 006352IF55N. Which engine do I have?
What do all the numbers stand for?
Also, where is the block casting number located? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Here are the locations of various engine casting codes. That engine serial number is for a first-series 1955 engine. 006352I = 0063521 ? = 62,521st truck off the assembly line (63521-1000 = 62521) F55N F = built in Flint, MI 55 = 1955 first series N = 6000 series truck Does it look like your truck has been repainted? What is the color of your grill (and the color of the inner part of the middle grill-bars)? What is the code on the door-plate (between the hinges on the driver's side of the cab)? Can you post a photo of the hood side-emblems? The block (and most likely head) date casting codes will most likely indicate 1955. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | My book shows the N suffix as a 261, optional on 6000, 2 ton.
See the USA in your vintage Chevrolet! My Blog | | |
