Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Wayne67vert, crenwelge, 1 invisible), 475 guests, and 6 robots.
Topics128,282
Posts1,058,494
Members48,490
I am working on a 54 1/2 Chevy 6400 big truck. Trying to find out if the engine is a 216, 235 or 261. The engine code is
006352IF55N. Which engine do I have?
What do all the numbers stand for?
Also, where is the block casting number located?
Here are the locations of various engine casting codes.
That engine serial number is for a first-series 1955 engine.
006352I = 0063521 ? = 62,521st truck off the assembly line (63521-1000 = 62521)
F55N
F = built in Flint, MI
55 = 1955 first series
N = 6000 series truck
Does it look like your truck has been repainted? What is the color of your grill (and the color of the inner part of the middle grill-bars)?
What is the code on the door-plate (between the hinges on the driver's side of the cab)? Can you post a photo of the hood side-emblems?
The block (and most likely head) date casting codes will most likely indicate 1955.
My book shows the N suffix as a 261, optional on 6000, 2 ton.
My Blog
