| | | Forums66 Topics128,162 Posts1,056,937 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#60660 05/19/2006 12:15 PM | Joined: May 2006 Posts: 237 Shop Shark | | Shop Shark Joined: May 2006 Posts: 237 | I'm trying to figure out if the 5.14:1 rear differential from a 1958 1 ton (Detroit Gear & Axle) can be switched out for a new gear. I'd like to get a 3.90:1 or a 4.11:1. I think there should be plenty available from 1/2 & 3/4 tons going to a smaller number. Does anybody know if these gears from the 1/2 & 3/4 tons will fit in the differential from the 1 ton's? Is there a source for new gears as opposed to scavenging old ones?
Also, is anyone aware of any type of locking axle assembly(Detroit Locker or other) or limited slip that is or was available for the differential?
My reasons for needing are two fold. I've got lots of intra-state trips on small state highways (60 mph speed limit) to make with large volumes of light weight material. I also go off road on occasion and would like to keep both sets of tires (dually) spinning.
Thanks for any help! | | |
#60661 05/19/2006 2:02 PM | Joined: Oct 2003 Posts: 363 Member | | Member Joined: Oct 2003 Posts: 363 | search the archives on Eaton, we just covered this about a week ago
As for the locker. Factory Lockers were available for the Eaton rears, so you can possible find one in the 67-72 replacement chunk. I have heard from the mud bog guys here that the 14 bolt FF gov-lok and detroit locker are almost a bolt in, but I have no details. | | |
#60662 05/19/2006 2:32 PM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Find a carrier from any 3/4 ton pickup from '46 - '72. You can get 3.90:1, 4.10:1, or 4.55:1 gear ratios.
4.55 is what you're going to find the most of.
Try to find an Automatic. These generally had the lower gear ratios.
I can't help you with the Posi question, though. Sorry. | | |
