3 members (55shaker, 3B, 1 invisible),
144
Mod | | | Forums66 Topics128,281 Posts1,058,472 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 41 New Guy | | New Guy Joined: Jan 2010 Posts: 41 | hi guys i hope u can help i have just restored my 63 and am needing oem or other inner wheel wells (not inner fender) something to protect the leading edge of the doors inside the fenders if there is such a thing someone must have come up with something to this obvious oversite by gm | | | | | Joined: Apr 2003 Posts: 943 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 943 | Never heard of anything OEM. I believe you would have to custom make something. My way of dealing with it is to put a protective coating on there. Something that would protect the metal while still looking original.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
| | | | | Joined: Oct 2009 Posts: 426 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 426 | Ive got a 63 that has these wells from the factory. There is an inner fender, outer fender, and then I have a "fender" that goes between the two. It has to be removed to get access to the side emblems on the fender, but I cannot locate any replacements. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Factory front fenders have an extension piece with a rubber flap factory-stapled to it, to keep road debis from kicking up into the front face of the door. Perhaps your front fenders don't have them installed. Is this the case? Otherwise, there is no other intermediate fender that goes between the two, that is OEM or factory. | | | | | Joined: Jan 2010 Posts: 41 New Guy | | New Guy Joined: Jan 2010 Posts: 41 | thanks ill try the rubber flaps | | |
