8 members (55shaker, Otto Skorzeny, JW51, 68ironhead, baldeagle, Ol'55, 3B, 1 invisible),
68
Mod | | | Forums66 Topics128,039 Posts1,055,473 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 19 New Guy | | New Guy Joined: Jan 2010 Posts: 19 | I have a 1950 3100 with a 54' 235 engine.Does the harmonic balancer suppose to have a bolt in the center of it?I do see something that either looks like a broken bolt or pin?In front of it I do not see any threads? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | No bolt on the early 6 in the balancer. Or at least not from the factory. Some guys will drill and tap the crank to take one, though. Otherwise, it's just a press fit.
Bill Burmeister | | | | | Joined: Jan 2010 Posts: 19 New Guy | | New Guy Joined: Jan 2010 Posts: 19 | Thanks Bill!My belt is not aligned it looks like the harmonic balancer has pulled away a little bit.Should I take it off and make it more snug on the crank?I tried to take a rubber hammer to it to make it slide on more but it didnot budge. | | | | | Joined: Jan 2010 Posts: 19 New Guy | | New Guy Joined: Jan 2010 Posts: 19 | Also the noise I get sounds like some kind of grinding!It only happens at idle and not during acceleration I checked the water pump bearings and the generator bearings and they seem fine.Would the harmonic balancer cause a grinding sound at idle if it is pulled away from the crank a little? | | | | | Joined: Nov 2009 Posts: 72 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 72 | Rubber hammer is not going to cut it, not enough force to slide Harmonic Balancer on Crank. I just put mine back on this afternoon using an 8 inch block of 2x4 and a sledge hammer and it slid right on. Just make sure you place that 2x4 on the Harmonic, don't want to risk tweaking it. Good luck | | |
