5 members (Gdads51, Bill Hanlon, TUTS 59, bobwithm, 1 invisible), 127 guests, and 3 robots.
Topics128,088
Posts1,056,124
Members48,435
#605881 12/31/2009 9:10 PM
I have a 64 C-30 with a 12' flat/stake bed. I need to replace the wood, and the strips in between. Does anyone make those metal stips that long? I've seen them for regular 8' pick-up boxes, but not for the 12' one ton size. Any suggestions?
That 12 foot bed may not be from GM. First thing I'd do is try to determine who made the bed and if they are still in business.
If you can't located the manufacturer, next thing to try would be to identify someone local to you that makes/sells beds for farm trucks and see if they have an answer.
Since the bed is not real likely to be a GM product odds are good you can find something that will work without worrying about originality.
http://www.mar-k.com/
Should sell most any length you need.
I expect they have a shape that's very close if not exact, certainly something functional.
http://www.mar-k.com/CustomForms/BedStrip_AngleStrip.pdf
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
It might be a little more expensive but you can get some of the shorter ones and butt weld them to the length you need. I'm going to be in the same boat here shortly with my 12' flatbed.
Bruce
My Trucks
Stuff I Collect
Several years ago I called Mar-k when I was planning to build my own flat bed, they said they could roll me strips any length I wanted and punch holes where I needed them.
I don't see these long bed strips as a problem...
Grigg
---All pictures---
Thanks guys! I will try Mar-K for the longer strips. I will not be actually doing the project till spring, but I'm gathering info and planning my attack.
Moderated by  Dusty53
