| | | Forums66 Topics128,037 Posts1,055,466 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | I installed a SM-160 universal turn signal unit in my 52-3100 /12volt truck last week and every thing works turn signals brake lights 4 ways , but the lights on the unit don't there are two green ,to indicate lift and right turn and one red to indicate 4 way any ideas as to why? I even ran a seperate ground wire to the unit and that did not help.
Thanks Pete | | | | | Joined: Jun 2009 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 45 | Pete, if you wired everything correctly, you must have a bad flasher. I had a flasher that worked but, it wouldn't lite the housing indicator. Are you using a three-prong flasher?
Jeremy | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Yes,I tried a electronic one first only one they had, and that did not work at all so I went and got a thermo one and it works every thing but the indicators but I did notice that it works even if I have only one lamp on say the front one or only the rear one and I recall in the "old days" if you had a lamp go out on the sys. it would not work so do you think I should try a differint flasher?
Pete
| | | | | Joined: Jun 2009 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 45 | Pete, I would visit the local parts store and pick up a Heavy Duty three prong flasher, and then plug it in. This should make the indicator light work.
On my '37 i only have the rear turnsignal lights wired. I think technology has us beat.
Another suggestion, Check your bulb in the housing. It maybe blowed.?
Jeremy | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Thanks Jeremy,I'll go get the HD flasher and give that a try and if it does not I'll check the lamps.
Pete | | |
