2 members (Bill Hanlon, Stovebolt48), 67 guests, and 2 robots.
Topics128,036
Posts1,055,458
Members48,422
#606079 01/01/2010 2:29 PM
I installed a SM-160 universal turn signal unit in my 52-3100 /12volt truck last week and every thing works turn signals brake lights 4 ways , but the lights on the unit don't there are two green ,to indicate lift and right turn and one red to indicate 4 way any ideas as to why? I even ran a seperate ground wire to the unit and that did not help.
Thanks Pete
Pete52 #606117 01/01/2010 4:35 PM
1 Offline
Pete, if you wired everything correctly, you must have a bad flasher. I had a flasher that worked but, it wouldn't lite the housing indicator. Are you using a three-prong flasher?
Jeremy
http://s925.photobucket.com/home/jeremy5756/allalbums
The only dumb question... is the question you didn't ask...- Unknown
1937ChevyPU #606133 01/01/2010 5:10 PM
Yes,I tried a electronic one first only one they had, and that did not work at all so I went and got a thermo one and it works every thing but the indicators but I did notice that it works even if I have only one lamp on say the front one or only the rear one and I recall in the "old days" if you had a lamp go out on the sys. it would not work so do you think I should try a differint flasher?
Pete
Pete52 #606318 01/02/2010 2:15 AM
1 Offline
Pete, I would visit the local parts store and pick up a Heavy Duty three prong flasher, and then plug it in. This should make the indicator light work.
On my '37 i only have the rear turnsignal lights wired. I think technology has us beat.
Another suggestion, Check your bulb in the housing. It maybe blowed.?
Jeremy
1937ChevyPU #606693 01/03/2010 2:23 PM
Thanks Jeremy,I'll go get the HD flasher and give that a try and if it does not I'll check the lamps.
Pete
