Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 135 guests, and 4 robots.
Topics128,275
Posts1,058,572
Members48,492
Any idea where to get brake parts (shoes) for a 1950 3800 series 1 ton - dual rear wheels....
also need to replace emergency brake cable, haven't found a supplier for it....should i simple fabricate one with baling wire? :-)
Boom!
'50 Chevy 1 ton dually daily driver, 1960 Ford F-100, 1972 GMC C-20, 1958 Kenworth, Cat D4, 1972 Ford F100 Ranger
I am sure you checked with the usual vendors before posting, but I'll add the link to Jim Carter's anyway
http://www.oldchevytrucks.biz/catalog1/0079.html
Jim Carter also has a 1 ton e-brake cable set.
http://www.oldchevytrucks.biz/catalog1/0083.html
Even though American Classic sponsors the site -- and I do always check there first -- I've found that they don't have much for the "bigger truck" crowd. Jim Carter, OTOH has had everything I've ever needed -- and then some.
If you're hell-bent on fabricating your own -- and let's face it, who amongst us hasn't thought about it -- I wouldn't use bailing wire to do it. I'd go down to a farm/industrial supply outfit and get some steel cable. Baling wire may "bail" on you when you need it the most... And that wouldn't be fun.
At all.
