2 members (Steveoreno, TPR57C),
106
Mod | | | Forums66 Topics128,186 Posts1,057,320 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#60592 05/18/2006 12:02 AM | Joined: Oct 2002 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 42 | Any idea where to get brake parts (shoes) for a 1950 3800 series 1 ton - dual rear wheels....
also need to replace emergency brake cable, haven't found a supplier for it....should i simple fabricate one with baling wire? :-)
Boom!
'50 Chevy 1 ton dually daily driver, 1960 Ford F-100, 1972 GMC C-20, 1958 Kenworth, Cat D4, 1972 Ford F100 Ranger
#60594 05/18/2006 2:31 PM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Jim Carter also has a 1 ton e-brake cable set. http://www.oldchevytrucks.biz/catalog1/0083.html Even though American Classic sponsors the site -- and I do always check there first -- I've found that they don't have much for the "bigger truck" crowd. Jim Carter, OTOH has had everything I've ever needed -- and then some. If you're hell-bent on fabricating your own -- and let's face it, who amongst us hasn't thought about it -- I wouldn't use bailing wire to do it. I'd go down to a farm/industrial supply outfit and get some steel cable. Baling wire may "bail" on you when you need it the most... And that wouldn't be fun. At all. | | |
