1 members (klhansen),
158
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 153 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 153 | I have a 64 C-30 with a 12' flat/stake bed. I need to replace the wood, and the strips in between. Does anyone make those metal stips that long? I've seen them for regular 8' pick-up boxes, but not for the 12' one ton size. Any suggestions? | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | That 12 foot bed may not be from GM. First thing I'd do is try to determine who made the bed and if they are still in business.
If you can't located the manufacturer, next thing to try would be to identify someone local to you that makes/sells beds for farm trucks and see if they have an answer.
Since the bed is not real likely to be a GM product odds are good you can find something that will work without worrying about originality.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | It might be a little more expensive but you can get some of the shorter ones and butt weld them to the length you need. I'm going to be in the same boat here shortly with my 12' flatbed.
Bruce | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Several years ago I called Mar-k when I was planning to build my own flat bed, they said they could roll me strips any length I wanted and punch holes where I needed them.
I don't see these long bed strips as a problem...
Grigg | | | | | Joined: Nov 2008 Posts: 153 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 153 | Thanks guys! I will try Mar-K for the longer strips. I will not be actually doing the project till spring, but I'm gathering info and planning my attack.
