4 members (2-Ton, baldeagle, BC59, 1 invisible),
74
9
Mod | | | Forums66 Topics128,020 Posts1,055,345 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 48 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 48 | Hi everyone; In reading The tech Tip by Jim Profit on the disc brake conversion what is the Top Hat that is mentioned and is a hard body Nisson a Sedan? I have a 36 pickup that I want to convert to frt disc brakes but was told that The calipers would hit my original wheels; What about using spacers? Thanks for the help...Richard | | | | | Joined: Feb 2000 Posts: 5,194 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,194 | The top hat spaceer is a piece that he made on a lathe. Its a bearing adaptor that looks like a small hat. The Nissan bearing inner diameter is different from the stock Chevy so he needed a adaptor to match them up. The Hard Body Nissan was a truck model from '86 -'97 ( http://en.wikipedia.org/wiki/Nissan_Hardbody_Truck ). Jim also hand made the caliper brackets. Joe | | | | | Joined: Apr 2007 Posts: 48 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 48 | Thanks for the info Joe; I should be able to find one at pull-ur-part...Richard | | |
