1 members (SandraD), 56 guests, and 5 robots.
Topics128,021
Posts1,055,355
Members48,420
#599190 12/08/2009 2:59 AM
Was anyone tried or thought about trying to make the outer trims out of door outer trims ?
New but in an Old Way !!!
Not me, but thinking about this, you may be able to use pieces of them for patches.
I've played with my old door trims and it seems a right door trim (dt) fit the middle window. straight side of the dt against the back side of the window. A right dt again would need to be used again but upside down with straight side against the front side of the window. Because if a left dt was used the top portion does not reach across because of the curve.
ps the front side of the window is a lil narrower the the back side so it would need to be notched.
J-Kat,
I took mine off and trashed them. I am putting solid glass in the sides. My rings were bad. I know where some are though.
[email protected].
Sully
I talked to the guy, he said nothing right know but check back with him. Thanks for the lead and new connection,,,, wheres he out of anyways ?
Oklahoma.
Keep looking. I would also go to the swap meet here on stovebolt and post a "parts wanted"
Merry Christmas
Sully
Hey guys i've got one trim ring bad out of the six. i do have two extra ones for the doors and it looks like it will take both of them to fix the one ring. The bad part is the the rings are so thin that it's going to be hard not to melt them while welding them up.. cross your fingers for me..
Working on a 1952 Chevy Suburban
theres a guy out here that was gonna tig weld patches on his trim using front door pieces. ill check if he ever did and try to get pics
nope sorry,, i went by earlier and still nothing had been done.. ill keep checking up on the progress
Thanks for checking... i'm going to cut and weld the front one as a test piece so i'll know if i'm using the right amount of heat... they are just so thin......
